Rear Camera problem
Bill_I
Connecticut
After a year of operation, the front camera began to intermittently double beep and the rear camera PIP would drop out. I reformatted the card and updated the firmware with no change. The card that worked all this time was a 128gb Samsung Pro Endurance. I think it was on the approved list at one time but no longer.
At first, I didn’t think it was a hardware issue. At some point, I realized the double beep would stop when I unplugged the rear camera. I re-seated the rear cam connectors with no change. The intermittent double beep would continue.
Some other things I’ve tried:
  • Replaced the Pro Endurance with a Sandisk Max Endurance 128gb.
  • Long formatted the cards using SD Card Formatter
  • Re-flashed firmware to V2.0 Build2: 20241016
  • Inserted card with camera powered down
  • Turned on camera using hard power connection
  • Formatted the card in the camera
  • Pressed camera reset button after firmware installed and camera booted
  • Reattached rear camera and reinstalled camera in vehicle GPS mount
At this point, the camera is not recognizing the rear camera at all.
I think the next step is to try a new rear camera cable?
Where can I get one?
Viofo A129 Duo Plus (not eMMC)
s/n A129PLUS22487495
Purchased 5/8/2003 from Blackboxmycar via Amazon
Firmware version V2.0 Build2: 20241016
HK3 Acc Hardwire Kit
Sandisk 128gb Max Endurance card.
After changing/reinstalling the firmware, be sure to manually default the cameras settings through the menu. Not likely the issue, but definitely worth trying.
I would try the Viofo 12V car charger and power cable to eliminate a power issue.
If the issue continues, then it's likely either the rear cable or rear camera.
Thank you for the reply. I forgot to mention that I did manually default the camera settings, no joy. Also, before posting I read through the "Intermittent Rear Camera" thread that was started in October 2020.
I just connected the 12v car charger and that made no difference.
I see I can order a rear cable for $18.99 so I guess I'll try that. Do you (or anyone else) know if a replacement rear camera is available?
DM'd you.
So, here's some additional info that might help others.
It seems there were at least two problems. At first, both cameras stopped working. I found that one of the butt splice connections between the add-a-fuse tap and H3-K Hardwire Kit had come loose. I replaced both with wire nuts and confirmed I had a good ground. That solved the power issue but the the front camera began to intermittently double beep and the rear camera PIP would drop out. As mentioned above, these are the steps I took.
  • I reformatted the card and updated the firmware with no change
None of this solved the problem. Next step was to replace the rear camera cable - as this was the least expensive option. I got a new one and temporarily connected it and the rear camera started working. When I pulled out the old cable, I found a small kink/exposed wire section. I re-ran the new cable (It's a PITA to pull it through the rubber wire bundle protector on the CR-V hatch but wire lube helps) and it seemed to work fine.
To be clear, the rear camera started working again after replacing the cable.
BUT, occasionally it beeped and stopped recording. I noticed that seemed to happen when I was stopped and there was some movement nearby. Checking my settings, I see that I had inadvertently ticked "Motion Detector" to "On". Toggling it off seems to have sorted things for the past several days. And viewing the mp4s on the card show both front, rear and parking videos now.
In case anyone is interested or has any other suggestions, here are my current settings for Viofo 129 Plus Duo:
Video Resolution = 2560x1600,30fps
Bitrate = High <== select High for best detail (Or Med)
Live Video Source = Rear Overlaid
Loop Recording = 2 min <== select 2 min Loop for reduced MP4 file size
HDR = Off <== enable for brighter grainy night video
Auto HDR Time = 19:00-7:00
Exposure = EVFront 0 / EVRear 0
Parking Mode = Auto Event Detection
Enter Parking Mode Timer = 90 sec
Parking Recording Duration = 12 hr
Parking G-sensor = High Sensitivity
Parking Motion Detection = Middle Sensitivity <== select Off for impact only detection
Time-Lapse Recording = Off <== never use when Parking Mode is enabled
Motion Detection = Off <== never use On when Parking Mode is enabled or driving
GPS = On
Speed Unit = MPH
G-Sensor = Low
Wi-Fi = Off <== Off for less heat and better image quality
Privacy Mode = off
Bluetooth Button Function = Mic/Action
Date Stamp = On
GPS Info Stamp = speed
Camera Model Stamp = Off
Record Audio = off
Screen Saver = 30 Sec
Boot Delay = 5 sec <== select 10 sec for Diesel or Electric vehicles
Date/Time = mm/dd/yy
Time Zone = -5 or (-4/w dst) <== match your region
Language = English
Beep Sound = All
Frequency = 60 Hz
TV Mode = NTSC
Image Rotation = Off
Rear Camera Mirror = Off
Format <== always Format new memory cards then format every 2 months
Format Warning = off
Default Setting <== always Reset to Default after updates
Car Number = CR-V
Custom Text Stamp = blank
Firmware = A129Plus_V2.0.20241016
