I found this over at Car Cam Central:
Optimal Settings
Resolution – 1440P: Lower resolutions have much worse video quality.
Loop Recording – 3 Minutes: Anything but off will work. 3 Minutes is a good compromise between too many video files and discoverability.
Exposure – 0EV: If it’s overly bright or dark you can change this number
WDR – Off: WDR does nothing but worsen night quality for minimal gains in dynamic range
Time Lapse Record – Off
Motion Detection – Off
GPS – On
G-Sensor – Off: No reason to turn this on
LDWS/FCWS – Off: Too many false warnings
Date Stamp – On
Record Audio – Depends: Make sure it’s legal where you live. Otherwise it’s your choice.
Screensaver – 15 seconds:
LED – On: Turns the status LED on/off. Helpful in checking for problems.
Date/Time: No GPS, adjust date/time here.
Time Zone: If you have a GPS your camera will calibrate time/date to the set timezone
Beep Sound: On Disabling this will disable audio notifications. Keep it on.
Frequency: Depends on your electrical grid. 60HZ in North America, 50HZ in Europe.
Format Warning – 30 Days:
Car No – Optional: Some people put their license/name here
I finally ordered the a119 from Amazon and just wanted to see if your experience with optimal settings match the above.
Dave
Optimal Settings
GPS – On
Date Stamp – On
Dave
