Hi everyone,
Been lurking a while and decided I should start posting!
I have an older Pruveeo F5 dashcam and it seems the battery isn't able to hold a charge anymore. The camera instantly shuts off when external power is lost, and the most recent file doesn't get saved as a result (camera not able to properly shut down).
Otherwise the camera seems to work fine, so I was thinking to replace the battery. I took the camera apart and it looks like it uses a 3.7V 320mAh battery pack (see attached).
Would something like this work as a battery replacement?
https://www.ebay.com/itm/122795956848
The voltage and amperage is the same, but the part at the top doesn't (it says HBT303040 EG on the Pruveeo's dashcam battery) not sure what that means...maybe just the battery model? So not sure if that makes any difference, or if I just need to make sure the voltage and mAh is same?
If that should work, I think just re-solder the new battery wires to the dashcam. Or anything else I should be aware of?
Thanks in advance,
Thanks in advance,
