Bungus
- Sep 10, 2014
- Burnaby, BC
- Canada
- 2 x Mobius, A, C2. 1 x Toguard CE685
Is this possible? Has anyone done this? Will it cause any problem?
I'm not sure I understand your question, but all lens can be switch between them, you just need to adjust the configuration accordingly. My first Mobius had an A lens, then I changed it to a B lens and now to a C lens (both bought together with a new unit). The Mobius that came with the B lens has now an extension cable and the A lens, while the v3 version that came with the C has now the B lens (in the case, without extension cable).
There is a situation where you have to cut some little plasic from the case in order for the lens cable to fit properly. See this post, the 4th picture.
Apologize for not making it more clear.
What I want to know is, if it's possible to just unscrewing out the A lens and screwing in the B lens without replacing the lens body. Just the part use to adjust focus.
