Sunny
- May 31, 2014
- Colorado
- More than I can review. ;)
Thank you @GearBest for providing Amkov AMK7000S action camera for review.
Amkov AMK7000S is available for $99.99 (or less when on sale) at Gearbest here: ***************************************************
Review Summary: Pretty good action camera for the price.
Daytime video quality is very good.
Night video is not that great with grainy yellow patches but not too bad and is enough to show objects.
I think it overexposes night to have better visibility and thus also brings in those grains and yellow patches.
4K is only 10fps so not much benefit but 2.7k @ 15fps and 1080p @ 60fps work very good.
There is anti shake option in the settings.
As a dashcam, you can't use this because of no looping option.
There is "Video Seamlapse Duration" in Wi-Fi app but even that doesn't make it loop.
I got card full error and had to format it to record further.
Audio is pretty good.
Wrist Watch remote works good but only from the front as that's where the RF receiver is.
Haven't tested underwater but I expect it to work fine with the waterproof housing.
Quick Links:
Daytime video screenshots
Daytime videos1 Daytime videos2
Night video screenshots
Night videos1 Night videos2
Wi-Fi App
Description:
AMK7000S is based on Sunplus 6350M SPCA6350 chipset and OV4689 image sensor.
It has built-in Wi-Fi and can record 4K resolution at 10 fps.
Video resolution: 4K (3840 x 2160) 10fps, 2.7K (2704 x 1524) 15fps, 1080P 60fps / 30fps, 720P 120fps / 60fps, VGA (672 x 380) 240fps
Removable 1150mAh battery, providing up to 90 minutes recording time.
IP68 waterproof housing for up to 40 meters underwater.
Other features are pretty standard with action cameras.
Quick unboxing video:
Package Contents:
![IMG_0018-Amkov7000S.jpg IMG_0018-Amkov7000S.jpg](https://dashcamtalk.com/forum/data/attachments/19/19574-b925d428dea90d4689b3b07053a2eb6b.jpg?hash=uSXUKN6pDU)
Amkov AMK7000S product box side by side with Mini 0826 box:
Amkov 7000S side by side with Firefly 6S, Mini 0826, G1WH.
Front view:
Power button, small screen and few LED status lights.
Bottom view: Battery door.
Left Side: Micro SD, micro USB, micro HDMI ports.
Top: OK/shutter button, status LED light, heat ventilation holes.
Right side: Wi-Fi button and LED status light.
Back: 2" LCD screen and LED status light.
Folders and Files:
SD card has CAR, JPG and VIDEO files.
CAR is probably for car mode with loop files but I just tested it in default settings so the files are under VIDEO folder.
Files have date/time so easy to find particular file.
Overall VBR for 1080p 60fps is 28.2 mbps.
Video 28.1 mbps and audio 128kbps.
![Amkov AMK7000S Folders and VBR.jpg Amkov AMK7000S Folders and VBR.jpg](https://dashcamtalk.com/forum/data/attachments/19/19573-8420c000fd3f9a5115d1e7d8686c92d0.jpg?hash=hCDAAP0_ml)
Tests to follow soon...
Quick Links:
Wi-Fi App
Description:
Package Contents:
- AMK7000S Sports Action Camera.
- Waterproof housing (IP68: 40m).
- Micro USB Cable.
- Sticky tape mounts.
- Strap mount.
- Wrist watch style remote.
- Dashcam/drone frame.
- Product manual.
- Several standard mounts.
Front view:
Folders and Files:
