Sunny
- May 31, 2014
- Colorado
- More than I can review. ;)
Thank you @PAPAGO! for providing Papago GoSafe 388 camera for review.
Product site: http://us.papagoinc.com/products/gosafe-388/
Conclusion:
PROS: It's very lightweight and small so very discrete from outside.
Works great and both video and audio are very good.
Has nice features such as stop and go, light reminder etc...
388 has slightly wider FOV than GoSafe S30.
CONS: The small sticky mount doesn't have enough leverage to angle down any further than what's in the video here.
Description:
The GoSafe 388 is designed to capture the entire road without taking up space on your windshield. Made with ionized molecular material to prevent bacteria build-up this micro-sized dashcam records in high quality 1080HD and 142° angle, so you are certain to capture everything in your path. The motion detection feature protects your vehicle from any mishaps during your absence while the Stop & Go, Light Reminder, and Driver Fatigue warning features help keep you focused on the road. The optional GPS antenna will help track your location and speed. The ability to record more footage is finally here! The GoSafe 388 is one of the few dash cams that can support up to a 64GB MicroSD card. This allows for much more storage space before it loops over old footage. Record even more important instances with amazing footage and precision.
Features
Ionized material:
The GoSafe 388 helps prevent any bacterial build up on the surface of the device by using a specially designed ionized material that helps ward off potentially harmful debris.
Compact and lightweight: measures 2.1″x2.2″x1.1″.
More info: http://us.papagoinc.com/products/gosafe-388/
Papago S30 Unboxing Video:
Package contents:
1. Papago GoSafe 388 dash camera.
2. Sticky mount.
3. Adata 8GB microSD with full size adapter.
4. USB car charger. 5V 1A
5. mini USB to USB cable.
6. Product manual.
7. One extra VHB tape.
Product boxes of GPSA-US (GPS Module), S30 and 388:
GoSafe 388 only comes with sticky mount but mounts are interchangeable if needed with S30.
Papago GoSafe 388 contents:
GPS module for Papago cameras (GPSA-US):
Papago GoSafe S30 and GoSafe 388 side-by-side:
Tests to follow...
Conclusion:
Description:
Features
Ionized material:
Package contents:
2. Sticky mount.
6. Product manual.
Tests to follow...
