D
Deleted member 85644
Guest
Because I am particular about power, maybe too particular, I want to "adjust" the wiring on an Type-C HK4 kit when installing my A229 Pro main camera onto the
rear glass of the hatchback of an Outback. The length from fuse box to rear window glass is about 5,4 meters. The 20 AWG wire from the HK4 voltage drop will be about
1,1 vdc.
I would like to place the KH4 at the rear of the car, replace the 20 AWG with 18 AWG, run the power wire to the fuse box and have a drop of only ,711 vdc. I will then
shorten the USB side to the 1 or 2 meter length I need from the HK4 unit to the dashcam.
Doing this will ensure max vdc and amps to the dashcam, reduce interference from my BT air pressure sensors, and give me something to tinker with in my old age.
Any recommendations or considerations?
1,1 vdc.
