samsung note 8 hotspot configeration probblems
Hyundai kona 2024
bristol uk
thinkware t700 lte
i have a samung note 8 and will not connect to personal hotspot. but it dose work on a samsung s8 .
anyone help
Have you checked the settings between the Note 8 and the S8 are the same?
I've heard people having wi-fi issues when wi-fi assist is on (i think it's called wi-fi assist on iphone... I can't recall what they call it on Samsung, download booster maybe?).
It's a setting that allows you to bounce back and forth from Cellular and wi-fi, if your wi-fi is spotty.
You could try to reset the dash cam, just back up anything you want to save from your SD card first.
Plug your F800 in, power the vehicle up and wait for the cam to turn on.
Then hold the Mic button and the Record button for 5+ seconds, this should format the cam and hopefully you'll have some luck.
You should hear some voice notification/beeps to tell you when it's done.
I have a note 8 and it works fine. It automatically disconnects the wifi on my note 8 when I connect via hotspot though. So I always have to remember to click the wifi symbol to put my phone back on wifi when I'm done using the dashcam hotspot for configuration.
