K KMING New Member Joined Feb 16, 2015 Messages 8 Reaction score 1 Country Australia Jun 15, 2015 #1 Cant find any way to reduce screen brightness at night. Night mode dose nothing and cant turn brightness down enough or disable screen at night.
parklawn Well-Known Member Joined Jun 21, 2013 Messages 663 Reaction score 255 Location Sudbury, Ontario Country Canada Dash Cam DR32. Innovv C2, C3 A118C Jun 15, 2015 #2 In the menu under LCD you should see an option named 'Standby' where you can select how long the screen stays on. Press 'Standby' and select 15 seconds. After 15 seconds the screen will turn off.
OP OP K KMING New Member Joined Feb 16, 2015 Messages 8 Reaction score 1 Country Australia Jun 15, 2015 #3 Thanks for the reply, it is set at 15 seconds, after that time it then comes up with the time and or speed you are going at.
parklawn Well-Known Member Joined Jun 21, 2013 Messages 663 Reaction score 255 Location Sudbury, Ontario Country Canada Dash Cam DR32. Innovv C2, C3 A118C Jun 15, 2015 #4 In the LCD menu try turning off the screen saver.
OP OP K KMING New Member Joined Feb 16, 2015 Messages 8 Reaction score 1 Country Australia Jun 15, 2015 #5 Thanks, that works, but it's a shame to loose that function, you would think Luckas would have worked out a better way.
