Tony lovelock
- Jan 18, 2017
- Hampshire
- United Kingdom
- Nextbase 422gw/Nextbase 212G & möbius C3 wide angle lens
as the title states above. Tbh I think I’ve probably taken the sd card out plenty of times since I’ve purchased it (approx may 2016) up until Today it was ‘springing’ in and out all ok. Then today it was not popping out as usual, so had to fiddle abit to remove the sd card with my finger nail. You can hear it slightly click when putting the sd card back in. I read somewhere that the outer case has to be removed and try pushing down on the sd card slot lug contact point? Will I need to dis connect the battery to gain access to this particular area?
Note:Once the sd card goes back in it does record ok
