flip9
- May 17, 2015
- Australia
- F770, SG9665GC
I wanted to check out my unused power supply that came with the cam so i opened it up.
The plastic case is either glued or ultrasonically welded but a little nudge from a vice loosened it up. Once its opened up you'll see two big capacitors and an inductor. If you turn it around you will see the 8pin regulator and supporting components. I searched the datasheet for the regulator chip and its rated for 24v 2Amps with operating temps of -40 to +85c.
It looks like a good power supply thats well filtered. The 5v output has at least 3 capacitors and ferrite beads (FB) on top of the reference design. The 12v input has 2 capacitors and a bead. (Different sized capacitors filter out different frequencies)
Feedback Pin has a resistor divider (R1 - 47.5k , R2 - 10k) which sets the Output voltage to 5.31v. It will be closer to 5.2v after the voltage drop from the 3m cable length.
Things of note:
-The wires of the USB cable is coloured incorrectly (but pinned correctly)
-I was expecting a diode on the input but a zero ohm link was used instead, possibly as a fusible resistor.
-Component number labels wont match ref schematic (board is used for other applications)
-Cig plug has a 3AG fuse rated at 1A
Ive obscured the chip and board info. The Red line is the output side after the inductor.
Things of note:
![8Fq7J63.jpg](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2F8Fq7J63.jpg&hash=3ced6050e38a6fc87c974c0d4a081c61)
