SGDCHW - Disable Parking Mode
scodabey
Just wondering if it is possible to use the hardwire kit purely as a way of powering the dashcam descretley when the vehicle is turned on? I don't need a parking mode, so when i leave the vehicle i don't want the parking mode to kick in, can the parking mode be turned off in the menu?
If you just want to conceal the wires you just snip off the cigarette plug from the original PSU that came with the camera ( at the plug ) the 12 V -> 5 V converter are in the little box on the wire.
But i also think its possible to not use the parking mode with the hard wire lit, or just do it once in a while, but then you have to enter the menus every time to engage / disengage parking mode.
But if you are not going to use parking mode you dont need the hardwire kit, just a add a fuse for your fuse box and then use the original power supply.
Argh i sit corrected. :)
