Kool Breeze
- Dec 16, 2017
- United Kingdom
I just bought a 0806 with hardwire kit and it seems to be working fine but if I remove it from the gps base plate it will fade and switch off after about 5 seconds. It's not possible to switch it back on then until reconnected to a power source (base plate or usb) - I thought it should run on its own battery for a short while once removed from base plate ?
I tried leaving it charging on usb overnight but same thing - disconnect usb, switch on and after about 5 seconds it dies. Other than that it has recorded fine with no erratic behaviour or missed recordings - I've only had it 2 days though
Should it run for a while on its own battery ?
thanks
thanks
