We suspect that the voice control was triggered by mistake which caused this special phenomenon. Please turn off voice control and keep observing if this issue disappears.Noticed there was a single beep while driving. Looked at the on-board screen but nothing was showing. Any idea what the 1 single beep is during operation?
Thank you. I have disabled voice command. It’s too bad. Using voice to enable and disable wifi is good.We suspect that the voice control was triggered by mistake which caused this special phenomenon. Please turn off voice control and keep observing if this issue disappears.
We totally understand. It is just troubleshooting to disable the voice control temporarily.Thank you. I have disabled voice command. It’s too bad. Using voice to enable and disable wifi is good.
Thanks. I will report back and share some results.We totally understand. It is just troubleshooting to disable the voice control temporarily.
So with Voice Command disabled, the single beep happened again. I happen to be in a parking lot getting ready to leave while inputting google map while I heard the beep. Quickly glanced at the A229 Plus and no message was visible, just a black screen. Any ideas what this could be?We suspect that the voice control was triggered by mistake which caused this special phenomenon. Please turn off voice control and keep observing if this issue disappears.
Thanks for the screen shot. I will purchase one of the recommended ones. I assume the Sandisk Extreme will work fine for the A229 Plus as it's not 4K?
Update. Noticed Viofo just removed the Sandisk Extreme card from their recommended section. Getting more reports that the Extreme card is now having issues even at 2K.
Link, and screenshot please?Noticed Viofo just removed the Sandisk Extreme card from their recommended section.
The de-listed card is still showing on parts of the website.![]()
What memory card is recommended for a VIOFO dashcam?
Micro SD Cards play an important role in dashcams, but not all cards are suitable to be used in dashcams. The footage recorded by dash cams is saved on a micro SD card, which is an essential component of the dash cam setup. Here are some parame...support.viofo.com
So sorry for the late reply due to the Chinese May Day Holiday. We will contact you to replace the camera for you.So this happened yet again. Single beep, date of recorded clip jumped to the year 2000 then unit asked to format the card. This is now using a new Sandisk Max Endurance card. Clearly, this is a defective unit. A few days waiting for support to reply. So frustrating dealing with this...
Thank you kindly. Appreciate it.So sorry for the late reply due to the Chinese May Day Holiday. We will contact you to replace the camera for you.
