Hey guys,
having a slight problem hard wireing my car cam into my mk6 golf... i have a smart power switch that i got free with my cam and it has never worked since i had it, im looking at buying a power magic pro.
here is the issue, i cannot test out the add a circuits installed to see if they work correctly wired in the photo in the fuse box as my smart power is faulty. does it matter which way around the add a circuit gets plugged into the fuse box (wire to top or bottom) ? reason i ask is the fuse box cover will only fit when i have the cables pointing down from the add a circuit like in my photo. The 12v 'only on' when ignition is on are at the bottom and if i have them with the wire facing upwards on the bottom row it stops the cover closing, can any one tell me of this works? as i cannot currently test it.
here is my fuse box, the fuses that are not used dont have terminations on them so i cannot use them.
