Smooth playback
Mikeact
Hello. I am not technical and know nothing about dash cams. However, I was persuaded to purchase a 512gw.
Can you please tell me why playback on my PC is not smooth.....it sort of keeps stopping ?
Also, I have tried hard to upgrade but have given up as nothing seems to happen, I don't mind waiting, but for how long ?
Thankyou from a first timer.
Stuttering playback can occur if you try and playback directly from the cam or card. Try copying some footage to your hardrive and playback from there. If there is still a problem it might indicate an issue with your PC.
As per Antoeknee advice.
But are you using Replay 3 to view your videos.
I think Replay 3 is fairly processor intensive and I get occasional stuttering on my PC which is quite powerful. (i7 CPU 8GB ram)
You could try another media player to see if that improves the playback.
If Replay 3 is causing problems you could try Irfanview. Great piece of freeware that displays almost any video or still format.
I have the same problem with the 512gw. not a problem with the 312gw using same settings (1080p@30fps) plus...... another thread methinks!!
