Software glitching or something I am doing wrong?
dbright007
Atlanta
SG9665GC, GT 680w
jokiin - if you remember me I got the cam several months ago and we rolled back the software version.
Cam seems to be running well and taking good images but it is having issues specifically with the date and time. I can go into settings and set the date/time but when I start recording it is off. Go back in, shows correct in the menu, but not on the screen or recording. Strange. It has been acting flaky the lately. One, only one, instance where I started the car and it just kept playing the startup sound over and over. Reformated and starts up fine last few times. I am curious about the time stamp issue though.
d
I will have to play with it a bit more to tell you for sure. The date is off by a day. Seems to show correct when I go into settings, but not on the playback on the screen. The time is only 3-4 mins off but same thing. GPS shows connected - wondering if is overwriting. Let me play with it for another day or so - was not sure if you were aware of an issue so thought I would ask.
I think I have it jokiin. Most likely user error. I went back and reset everything and has seemed to work fine the last day.
One question - in the top center of the display on the cam now there is an X. When I replay a vid it shows an X in the bottom center. What have I done now?
After that, mods can delete this thread - not much value to it. Just want to figure out the X
Thanks, will do. Other than that loving the cam.
Camera seems to be aimed a bit high. Lower it a bit (50/50 sky/road) and your exposure should be better, not quite as dark.
Will give it a shot. Was just trying to keep the hood out of the image.
Really not necessary, and probably not a good idea. In the event of an accident it will be better for it to be in the frame to make it easier to tell where other objects (vehicles, bikes, pedestrians, buildings, etc.) are relative to you.
I find the 50/50 I suggested works well in that regard and is still high enough to show traffic lights right up to the point where I'm passing under them.
