demosethell
- Jul 9, 2018
- Portugal
has anyone tried to use a solar powerbank to power their A129 while in parking mode? What was the output? Does it hold?
Although I can see the attraction to the concept, I've never been a fan of solar powered power banks for the simple reason that leaving lithium-ion batteries baking under the hot sun is not a wise thing to do from a safety perspective or for the longevity of the cells in the power bank.
I don't use my car everyday and only have street parking. I've had a couple of hit and run (more than $3000 damage) and received lots of bumps and dings from careless drivers. That is why I was looking into solar panels to run dash cam and think the most economy option is to have 2 or 3 high capacity power banks and just swap them.
I am now looking at lithium iron phosphate batteries because they are a safer battery but more expensive.
Unfortunately, no camera would catch the offender. Angle is bad.Here are the 3 hit and runs that I have experienced with my cars. Not a very good feeling coming home and seeing this done to your car. I'm pretty sure a dash cam would have caught these incidents and the offender's license plate.
View attachment 42697View attachment 42698View attachment 42699
I had to disconnect the power leads from my power banks every time I planed to use a "parking mode" until I put a switch on it (on a power leads).Is it possible to keep a power bank connected along with the power lead from the lighter socket for parking mode, or would I need to connect and disconnect the appropriate power leads.
it would be but... my power banks don't get charged while provide a pass through charge. that's what a "pass through" is, I guess.Would it be better to power it from a power bank with pass through so the bank is charging when the ignition is on and powers the camera.
lucky you. 1 camera draws about 0.5A, a power bank charges at up to 2A if ~50% depleted. should work in your case. what's the brand / model and capacity of your power bank?I have one that charges at the same time as powering a device.
Not sure if the journeys I do would enable the charging to keep up with demand though.
