I received this reply about the noise.
Hi friend,
Thanks for your reply. My friend, we can open the link and download it this time. We have checked the sound of the video, it is white noise. It's because of the auto gain control. When the environment is rather quiet, the auto gain will increase a bit trying to capture some level of sound. The gain increases, the background noise white noise increases. When there is any human voice or regular sound, the gain will be back to normal again. There is really not much we can do. We can not turn the auto gain control off, or the sound quality will be not balanced and not pleasing to hear. It is same for our other camera, like #16 camera, mobius 1 camera and mobius 2 camera.
Sorry for the confusion.
Regards,
Mandy
"White noise" is simply another way of saying the same thing as "signal to noise ratio" which results in the
"background noise common to all electronic audio devices which have this to one degree or another" that I described in my first reply to this thread, otherwise known as the noise floor.
As a result of the message you received from Mandy at eletoponline365 I did a little testing with a Maxi as well as with a Mobius 1. I put both cameras into a sound deadened space (a clothes closet) and let them record for a while. The Maxi produced the same exact S/N hiss (white noise) that yours does. The Mobius 1 creates an absolutely dead quiet recording.
I had never noticed this before and I don't think anyone else would have either when using the Maxi in an automotive or FPV environment where ambient noises would drown out any low level hiss. Nevertheless, I think you've unearthed a previously hidden flaw in the Mobius Maxi. I'm of the opinion that the camera should not do this. The AGC (automatic gain control) seems set too high. When I recommended trying a lower audio volume setting I thought perhaps the AGC would be turned down as well but apparently that is not how it works. The AGC issue here is equivalent to what I decribed when I said,
"If you have a stereo system in your home and you turn the volume up all the way with no music playing you will hear the same exact sound." As far as I know, the AGC level is something that Mobius can address in a firmware update, assuming that the chipset itself doesn't inherently have a S/N ratio that is so low that the noise floor can not be compensated for.
One of the things that has always impressed me about the Mobius 1 camera is the outstanding audio recordings it is capable of. In many situations carrying the Mobius as a pocket camera I have used it as a stand-alone audio recorder with excellent results. Using the camera to record wildlife in natural settings the perfectly quiet but sensitive recording is also impressive.
If the Mobius 1 can produce such clean, quiet recordings, then the Maxi should too. At the very least, it should be quieter that it is. Nobody should have to turn down the sound on a recording to get acceptable clear audio, especially on a camera that is being used to capture evidentiary documentation.
Mobius should add this issue to the list of things that need to be addressed in any future Maxi firmware updates!
