JaseQ
- Sep 18, 2015
- United Kingdom
- Blackvue 650 2 CH
I have the Blackvue 650 2CH dashcam which is hardwired using the Power Magic Pro. Since buying the unit in September I have had no end of issues with it, sometimes working as it should, other times it just doesn't do as it should. My latest problem is this.
The unit doesn't always power up when I start the engine and sometimes comes on 10minutes to 30 minutes whilst driving, I believe this to be some issue with the PMP and I'm getting this replaced on Monday so hopefully that will solve that problem. Now when the unit does power up the GPS light comes on so clearly there is power getting to the unit but that is all that happens. The unit doesn't record, no Wi-Fi light comes on, the format button on the side doesn't do anything. I have tried 2 SD cards which I have formatted on my computer and I have put onto these both firmware 2.002 and 1.009 in case there are firmware problems, I have checked these on my computer and it says both firmwares folders are present but when I put these into the device I get absolutely nothing. It's like it doesn't even recognise the card is in the device. Surely if it was a faulty SD card it wouldn't have the folders on in the first place?
I am now at my wits end with everything so does anyone have any idea what the solution would be to this?
