liamstears
- May 6, 2018
- United Kingdom
Evening all, successfully upgraded my unit from standard K2S to a K2S Pro so thought I would run through the steps quickly and share some images
The difference between the standard and pro is only the firmware and the camera units so to upgrade unplug both cameras, put pro firmware on an SD card and update the firmware with cameras disconnected, then connect new Pro cameras, done!
Results:
Standard camera:
New Pro Camera:
With both images above all settings are the same, both were set at 1080p with all standard settings
I must say at standard settings my eyes find the standard cameras more appearling, but I do suppose the Pro cameras colours are more "life like"
I haven't yet played with any settings or tried the new WDR option, maybe you guys can give some suggestions of what you think will be best? What do you guys things of the difference between the 2? The pro looks as though it has a wider capture area and I do need to adjust it slightly...
Results:
Standard camera:
New Pro Camera:
