helg
- Feb 9, 2018
- Germany
- M4+, miniONE, Mola N3, mini5, X5 Pro
I have some empiric evidence of an unintended switch between the USB mass storage and UVC webcam on mini5,
which i wanted to share, because streaming video over USB can be an interesting option.
Here is the normal 'USB mass storage' mode, which allows you to access the eMMC user partition:
and after that it switched to UVC webcam:
Code:
[ 750.185054] usb 1-3: new high-speed USB device number 11 using xhci_hcd
[ 750.334180] usb 1-3: New USB device found, idVendor=0525, idProduct=a4a5, bcdDevice= 4.09
[ 750.334188] usb 1-3: New USB device strings: Mfr=3, Product=4, SerialNumber=0
[ 750.334193] usb 1-3: Product: Mass Storage Gadget
[ 750.334197] usb 1-3: Manufacturer: Linux 4.9.37 with dwc3-gadget
[ 750.335921] usb-storage 1-3:1.0: USB Mass Storage device detected
[ 750.336241] usb-storage 1-3:1.0: Quirks match for vid 0525 pid a4a5: 10000
[ 750.336310] scsi host3: usb-storage 1-3:1.0
[ 751.357477] scsi 3:0:0:0: Direct-Access Linux File-Stor Gadget 0409 PQ: 0 ANSI: 2
[ 751.358231] sd 3:0:0:0: Attached scsi generic sg1 type 0
[ 751.358268] sd 3:0:0:0: Power-on or device reset occurred
[ 751.358597] sd 3:0:0:0: [sdb] 120397824 512-byte logical blocks: (61.6 GB/57.4 GiB)
[ 751.358751] sd 3:0:0:0: [sdb] Write Protect is off
[ 751.358758] sd 3:0:0:0: [sdb] Mode Sense: 0f 00 00 00
[ 751.358907] sd 3:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 751.360254] sdb:
[ 751.363011] sd 3:0:0:0: [sdb] Attached SCSI removable disk
[ 753.000484] usb 1-3: USB disconnect, device number 11
[ 753.007034] sd 3:0:0:0: [sdb] Synchronizing SCSI cache
[ 753.007052] sd 3:0:0:0: [sdb] Synchronize Cache(10) failed: Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
Code:
[ 753.412803] usb 1-3: new high-speed USB device number 12 using xhci_hcd
[ 753.561759] usb 1-3: New USB device found, idVendor=1d6b, idProduct=0102, bcdDevice= 4.09
[ 753.561766] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 753.561770] usb 1-3: Product: Webcam gadget
[ 753.561773] usb 1-3: Manufacturer: Linux Foundation
[ 753.563178] uvcvideo: Unknown video format 3132564e-0000-0010-8000-00aa00389b71
[ 753.563199] uvcvideo: Found UVC 1.10 device Webcam gadget (1d6b:0102)
[ 753.566802] input: Webcam gadget: UVC Camera as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/input/input22
