System time incorrect
Echan123
Hong Kong
Hi
I’ve just installed a f800pro and it has been running for a while. As my car is parked inside a building with no GPS reception, normally the f800pro could connect to GPS on the road within a few minutes. However, I found that the system time is always 1 hour earlier than current time. I’ve checked that the time zone is correct (UTC+8). How can I correct the system time in this case?
Hi
Finally, I fixed the system time by driving the car to a open space than reset it to factory default setting and also change the UTC offset back and forth. All the recorded time are then correct.
