Nigel
- Jul 7, 2014
- Wales
- United Kingdom
- Gitup F1+G3ꞈꞈꞈꞈꞈ Viofo A229ꞈꞈꞈꞈꞈ Blueskysea B4K
Taxi / Uber Cameras - Viofo A129 IR and Blueskysea B2W Comparison
Viofo and Blueskysea have both recently introduced new dashcams aimed at use in Taxi / Rideshare vehicles, although they can also be used in private vehicles as an alternative to dual front/rear cameras since they provide easier installation and provide more evidence since they cover the inside of the cabin and the view through the rear side windows as well as through the rear window.
Both cameras are dual channel and feature front facing and rear facing lenses designed for mounting at the front of the vehicle rather than on the rear window. As a result they can record the front view, driver, passengers, the view out of the rear and the view out of the rear side windows (when not blocked by a head) - a lot of evidence in the case of any disagreement. Of course there is less chance of successfully recording the number plate of the car behind than with a rear window mounted camera, the car behind needs to get quite close for that, plates can also be read through the side windows.
The lenses on the B2W can easily be rotated to point towards the driver's door to record conversations with police/customers/etc., while the A119 IR rear camera is a seperate unit so is far more flexible in it's positioning, it can even be mounted at the back of the car facing forwards to record the cabin from the rear, a long cable is provided for that purpose in addition to a short cable for mounting around the rear view mirror area.
The main features of these models are:
Viofo A119 IR
Viofo A119 IR
- Channels: Dual channel video (Front + Cabin as seperate modules).
- Resolution: 2K front + 2K cabin (1920x1080 FHD + 1920x1080 FHD).
- Maximum Bitrate: 16+16 Mb/s.
- Field of view: 140 degrees horizontal front, 160 degrees horizontal rear.
- Horizontal lens adjustment: None, unless cabin unit is attached to rear view mirror or other adjustable mount.
- Cabin Illumination: Infrared 850nm, with IR sensitive cabin camera.
- IR-cut Filter: None.
- Image Sensors: Sony IMX291 + Sony IMX291.
- Parking Modes: Buffered Motion Detect, Timelapse, Low Bitrate.
- WiFi: Yes.
- Bluetooth Remote Control: Yes.
- LCD Screen: 2"
- GPS: Yes.
- Hardwire Kit: Optional.
- CPL Filter: Optional.
- Channels: Dual channel video (Front and Cabin built into main unit).
- Maximum Bitrate: 16+8 Mb/s.
- Field of view: 132 degrees horizontal.
- Horizontal lens adjustment: Yes.
- Cabin Illumination: Infrared 940nm, with IR sensitive cabin camera.
- IR-cut Filter: Automatic|Manual
- Image Sensors: Sony IMX307 + Sony IMX307.
- Parking Modes: G-sensor triggered.
- WiFi: Yes.
- Bluetooth Remote Control: No.
- LCD Screen: 2"
- GPS: Optional.
- CPL Filter: No
