AndyP
- Jan 6, 2015
- United Kingdom
- Blackvue DR-650GW
Hi all,
Apologies for the length of my first post, but hopefully going through it will help work out what i might have done!
I received a Blackvue DR650 for Christmas, along with the Power Magic Pro. I've installed the camera(s) with no problem, but unfortunately the same can't be said for the Power Magic Pro![Frown :( :(](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f641.png)
I am using the add-a-fuse piggyback holders, and determined (I think!) the correct way round to insert these with their associated fuses, based on amongst a few other sites: http://www.tsisecuritycorp.com/TSI_USA_Fuse_Plugs_ATO_ATC.html
The only thing I can think of that I might not have done according to the instructions was to insert the cables in the main body of the device before attaching the individual wires to the fuses/fusebox/earth.
As I pulled the ground cable to attach it to something metal, it brushed the frame holding the fuse box & there was a brief spark. However, once all was plugged in, the box appeared to be OK (LED light was on, and the camera powered up as normal when plugged into it).
I then set about tidying up the cables to zip-tie out of the way. Unfortunately, when I turned the box on again, the LED did not light, and the camera no longer powers up from the box.![Frown :( :(](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f641.png)
I've just noticed the manual states 4.8W as the current consumption - shouldn't they mean Amps? I have used 5A fuses - is it possible they might have been too high?![Confused :confused: :confused:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f615.png)
Does anyone have any suggestions as to what I might try next, or is it likely I have fried the Power Magic Pro...?
Thank you in advance for any help you can give me.
Andy.
Andy.
