I wrote this up in the other thread. I thought it may be good to post it separately.
I ordered mine from blackboxmycar.com. I was in town so I picked it up in person at blackboxmycar's office in Richmond, BC, Canada. The customer service has been top notch. Justin was always quick to answer all my questions (and I had a lot of questions). I ordered the F770/Cellink B pre-order bundle. It comes with a 64GB SD card, hard-wire kit, a circuit tester, and installation accessories, and a couple add-a-fuses. I also ordered with the rear camera.
At their office, I was able to see F750 andF770 side by side. The F770 is noticeably smaller than the old model. The new model is slimmer and more streamlined. Gone is the stuck-out silver cylinder-shaped lens housing. The lens on the F770 is part of the unit's body. There is also a compartment on the side of the body for better cable management. The windshield attachment is now a thin solid piece of plastic. So the dashcam will be much closer to the windshield and appears even smaller than the old F750.
I installed it yesterday with the rear camera. On my BMW M3, fuse 155 was recommended on Blackboxmycar's YouTube video for F82 M4, for some reason, fuse 155 has no power for me. I didn't test it before so I don't know if it was like that or I did something wrong to the car. I ended up using fuse 159 for ACC. The add-a-fuse also came loose, so I had to repair it. But all is working after a couple hours of trial and error. Also thanks to Justin @ Blackboxmycar for extending my hard-wire cable so it is long enough for my car (fuse box in the trunk).
Some random notes:
[EDIT: Added pictures.]
blackboxmycar.com will be sending me new right-angle cables to replace the straight ones I have. My hard-wire power cable already has a right-angle connector. New orders from blackboxmycar.com will include right-angle cables (power and USB cable if you order with the rear camera) so the flap can be closed.
Some random notes:
- I am glad I bought my camera from BlackBoxMyCar. They are good people and take good care of their customers. I picked up my order in-person while I was in town. Justin knew my car needs an extra long hardwire cable and he extended it for my without me asking.
- I installed the F770 with a Cellink B battery. My car has a Lithium Ion battery that I heard is expensive. I like that the camera won't drain power off my car's battery.
- My hard-wire cable has a 90-degree power connector, which is perfect. But it also is very difficult to disconnect it from the main unit. I used a tin tie from one of the cables to make a loop for better leverage to pull out the connector when I needed to during installation.
- The USB cable that comes with the rear camera has a straight USB cable connector so with the rear camera installed you can't close the flap on the F770 connector compartment. BlackboxMyCar will be sending customers the right-angle cables later.
- I disabled all driving assistance features as my car already has them all built-in
- I disabled the LED on the F770 camera. But the blue LED on the rear camera can't be disabled. I will need to find a black electrical tape to tape over it
- The boot up time is fast, maybe about 5 to 8 seconds. Unlike what others have complained about the F750's boot time
- The buttons are decently sized, but they are not back-lit so it is hard to find which one is the right button to press in the dark.
- Downloading clips from F770 to your phone over WiFi is fast, or at least it doesn't feel slow to me.
- Streaming clips over WiFi is also fast, it takes a second to buffer and then it plays like normal
- Video quality is good for front and back. My last dash cam is a mini 0803. So take that with a grain of salt.
- It audio recording is of good quality. In-car conversation is loud and clear, even with my loud car. In contrast, it is very difficult to hear the recording with my mini 0803.
- I thought F770 would support 128GB SD card, but the manual only says up 64GB as the largest.
- I was able to disable all the voice prompts (e.g. "starting continuous recording") except it still speaks and tells you how many motion detection was recorded in parking mode when you switch on your car (i.e. ACC has power again)
- Time-lapse is an option for parking mode. It records one frame per second. The video is strung together in 30-minute files. It is a non-stop recording mode. No audio is recorded in this mode. It is useful if you want continuous recording while you are away from your car and don't want the recording to take up all your storage space. It is kinda cool but it isn't very useful to me. I tested it once and switched back to motion detection mode.
- I have not tried the red light camera alert feature. I need to download the data file first.
- F770 user manual can be found here: https://fccid.io/pdf.php?id=3027630
- http://www.thinkware.com/Support/Download doesn't have F770 listed yet.
- Internal pictures from fccid.io: https://fccid.io/document.php?id=3027628
![13KvxBR.jpg](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2F13KvxBR.jpg&hash=52f6e133c2305bec57ab22853c562ac8)
![CvdkYfo.jpg](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FCvdkYfo.jpg&hash=b3493301f26ae1362fac5f7e07a9d355)
![ob4auMy.jpg](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2Fob4auMy.jpg&hash=445b2f7b1923e07c2b926eef29f22aba)
![p99rt0c.jpg](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2Fp99rt0c.jpg&hash=061fd188f612df13f37c94f958cc8116)
![mWqs6Ps.jpg](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FmWqs6Ps.jpg&hash=e70df4e13993b779bcb38eeeb707e38d)
![QNHP39y.jpg](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FQNHP39y.jpg&hash=73bb93927a6474ae0eb5b0a2e3e724eb)
![GWA7aqs.jpg](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FGWA7aqs.jpg&hash=b8900d26b1ca0db6e93abc7fa57c85fa)
![538lp0j.jpg](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2F538lp0j.jpg&hash=6f527912640f92769675737e74076d1f)
![YLR3qFq.jpg](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FYLR3qFq.jpg&hash=0d63f8d917149eb456c111b134d5e4f5)
![4CsyHFK.jpg](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2F4CsyHFK.jpg&hash=5413dc7cd6f754da2952b8e8bcf05a44)
![b2wwqsO.jpg](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2Fb2wwqsO.jpg&hash=7978bb115481adee947133763eeaced3)
![dpmNGJy.jpg](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FdpmNGJy.jpg&hash=6e60a8ecb95b1a6ba7510920a4d90174)
![fBewAmE.jpg](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FfBewAmE.jpg&hash=556968a6e7ef321502bedac169189b9f)
![OdxqS2k.jpg](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FOdxqS2k.jpg&hash=d9885d42d67089e6c2f6c662be35ffe6)
![Z8sSswE.jpg](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FZ8sSswE.jpg&hash=aaed171b0d875f38527602d510dda703)
![o92bMRx.jpg](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2Fo92bMRx.jpg&hash=1421a70006a33e624984d6d3d15f9c9b)
