Third channel as side camera
driver2
Romania
As posted in an earlier thread, I ordered a standard 2-channel A329 with an additional rear camera as a side camera. My car is a sedan with a D pillar, so there is a small window between the C and D pillars where the third camera goes. Below some pictures from each camera:
Front
Side
Rear
There is a small overlap between side and rear, as seen by the markings on the road. The side camera is configured in fish-eye mode, and therefore it can capture the interesting stuff.
I also tried the 21:9 aspect ratio and I can say it is the best option for front and rear, as it cuts out the top and bottom of the image, leaving only the part where the action happens. But this changes the ratio also for the side cam, where all the information is needed. So a question for @VIOFO-Support: would it be possible to record front and rear with 21:9, and interior (or, in this case, side cam) with 16:9? I think it would be useful, because the front and rear files will be smaller, leading to less wear on the storage, and also the processor should have less workload.
So you use the two standard rear cam, and one rear cam using as a side cam?
Yes, exactly as Karagandinez suggested in this post. The extra 'rear' cam is seen as interior cam, and also the saved files have the 'I' letter in the name. Even the recordings at night are black and white if the setting 'IR LED' is 'auto'.
