This is quality camera?
Yes i have the same mount on the E2 camera, and it is not my favorite way of mounting any camera, but i have not noticed any "jello" in recordings i have made.
But granted the weather in Denmark are low light and grey so i might not have noticed it.
There are a sort of cobble stone street in town and going over that you can see by the dashboard in view that the footage was shaking VS the Viofo A229 camera i have beside the E2.
But i have not noticed anything driving on regular streets.
I think better solution would be adding screws left and right site. I wonder how to fix it.
When i installed the E2 system it felt okay for what it is, but i did not pay attention to how the mount are hinged up there just that it was tight.
Still with a hard enough collision i am sure this like man other systems will flip forward and so when stopped will just film the sky.
I am going for a short drive later, will have a look at my mount as good as i can with the camera installed in front of mirror.
Maybe e3 its more weight than e2? My e3 shaking as hell.
Well it is larger, sadly i have no way of weighing the camera, but maybe the vantrue product page have weights.
Didn't have that problem on my Vantrue E3 - at least it's not noticeable on recorded videos... But then I was using the mount that came with the Vantrue E2.
I would assume the 2 mounts are the same.
It could be Airflames are just looser in that joint VS what we have.
I would also assume there was some kind of boldt there, but it might be hidden by something decorative ?
I did no drive earlier but totally forgot to taker a look at the camera.
Ill see if i can make a drive tomorrow in daylight too, i do need to verify the new card in the E2 are recording fine, but i think it is, at least not gotten any alerts from the camera, which i assume it would do.
私も動画のようにカメラが振動で揺れて完全に固定できません。
VANTRUEにGPSマウントを交換してもらったけど改善しませんでした。
Hello Suji,
sugi wrote...
I also can't completely fix the camera because of vibration like in the video. I had VANTRUE replace the GPS mount, but it didn't improve.
Maybe try packing the mount by adding a little tape or similar between the camera & the mount?
Take them apart & add the tape etc.
I've also "fixed" things sometimes by applying a little heat to the item to close the gap.
You've gotta be very gentle & cautious when applying the heat though.
Do NOT go crazy with it. You only need a slight closing of the gap to nip it up.
Thank you Michael23,
Hello Suji,
sugi wrote...
その方法を試してみます。
ありがとう!!
You're welcome, Suji.
Hope you are successful.
