Too much noise in video
Adeses
Spain
Hello friends. I do not speak English well. Google translate is my friend.
I bought this camera two weeks ago.
The videos with little lighting, have a lot of noise. Even with ISO 50
I see some videos on youtube with very little lighting and are without any noise.
Example:
Example of one of my videos at 2 pm:
https://mega.nz/#!qwgXiTiK!5aB9YopBrqgg20Ze2MqTFfdQcYq1APGCV3_fRWFEPzE
This is configuration:
Frequency: 60 Hz
Tv Mode: NTSC
1080P / 60FPS
White balance: Auto
EV: +0.0
Shutter Speed: Auto
Iso: 50
Color: Normal
Gyro: On
WDR: On
Sharpness: Strong
Metering: Average
Fov: Wide Angle
Video Birate: High
Is this normal or my camera is faulty?
Sharpness: strong
Is not good if you don't like noise, normal is better, even better is soft and then sharpen it on your computer.
Video Bitrate: High
Can also increase the amount of noise visible.
Also, uploading to YouTube will reduce the amount of noise as it gets lost in the YouTube compression so the videos you linked to may look cleaner than they really were. You can do the same by reducing the bitrate on your computer if you have a video editor with good compression software.
More tests
Today the day is cloudy.
https://mega.nz/#!D5JHDBAR!MI1dfPtK81FRO3iNYPSUiayFGjBvAYrIbPyUQtvouWI
Frequency: 60 Hz
Tv Mode: NTSC
1080P / 60FPS
White balance: Auto
EV: +0.0
Shutter Speed: Auto
Iso: 50
Color: Normal
Gyro: Off
WDR: Off
Sharpness: Soft
Metering: Average
Fov: Wide Angle
Video Birate: Low
https://mega.nz/#!XgJU0bTC!2Mx61KSek1VjrUdIkmYlaEm7VKbhH0gocGitUyijFEw
Frequency: 60 Hz
Tv Mode: NTSC
1080P / 60FPS
White balance: Auto
EV: +0.0
Shutter Speed: Auto
Iso: 50
Color: Normal
Gyro: Off
WDR: Off
Sharpness: Strong
Metering: Average
Fov: Wide Angle
Video Birate: High
https://mega.nz/#!T85zCbZK!eTQxvwKbpqKig55pHq76Qj88_jRS3KI-tZQWBHpUqlQ
Frequency: 60 Hz
Tv Mode: NTSC
1080P / 60FPS
White balance: Auto
EV: +0.0
Shutter Speed: Auto
Iso: Auto
Color: Normal
Gyro: Off
WDR: Off
Sharpness: Strong
Metering: Average
Fov: Wide Angle
Video Birate: High
What do you think about it?
Hello, i have similar problem with my git2, also too much noise, video looks like from camera under $20.
Tried 1.3 1.4 and now 1.5 beta firmware and nothing has changed.
