Jon W
- Nov 21, 2014
I recently got the Mobius (I got the pro kit so that I don't have to worry about adapter/SDcard compatibility.)
Mounting it on my dash with the magnet mount, and plugging it into the cigarette lighter with the adapter works fine.
It starts recording when ignition is turned on.
However, it doesn't stop recording when ignition is turned off.
This means that it overwrites a lot of previously recorded data with a static view of the front of my parking lot for as long as the battery lasts.
I'm using firmware 2.10.
Is there some setting or other way to get it to turn off when the ignition power is removed? (Without replacing the battery with something else like a supercap, or a smaller battery, that is.)
What are all the settings that actually matter to make it behave right?
Separately, I've looked through the manual for the motion sensitivity setting, but I don't quite understand what this does. Where's a good reference for this feature? Is it acceleration-based or image-change based?
And, if motion detection is the solution to my above desire (don't record after ignition off,) will it properly go into standby mode automatically when ignition is powered on again? If so, what are all the settings that matter to make it behave that way?
