Understanding the charge indicator
Edward Heaney
[SOLVED} After installing the memory card I opened up msetup, and made a few changes. I exited the setup program; disconnected the mobius; and then reconnected the mobius to the laptop. The rear led light is on, and the top light is a solid yellow. Does the yellow indicate that it is charging? Will it be a solid red when it is fully charged? These things are not mentioned in the manual.
When hooked up to the laptop will it charge if it is on; or must it be turned off?
I reread the manual, where it states that a solid green light indicates that it is charging.
