Noebuhdy
- May 26, 2015
- SG9665GC V1, V3. SG9663DC. Mobius C2.
Ran into an issue where the hardwire kit in my car causes the battery to drain flat, which makes no sense initially because it has the cutoff voltage set to no less than 12.0V
But turns out that there's a energy draw in the room-interior circuit (accessory).
Anyway, went back to the idea of using a 20,000mAh usb battery to imitate parked mode but this tends to deplete the battery approximately 10 hours, depending on settings. I don't know if there's a dashcam setting that can stop recording after a certain time while not in parked mode.
Then the idea came about using a usb device that can turn off everything after a set time, say 4:00 hours after parking, so the setup would look like,
[USB battery] -> timer switch (set to 4hrs) -> dashcam.
then obviously after 4 hours, the dash cam powers off as well as turn the battery off.
Is there such that can work?
