Has anyone used the Viofo WM1 as a rear dashcam and can provide their experience? I was helping someone with installing their Viofo A119 Mini 2 dashcam as a front dashcam in their 2024 Honda CRV. Then was thinking what would make sense to install as a rear dashcam. We did not go with a 2 channel dashcam solution as we wanted independent front/rear dashcams to reduce the chances of a failure affecting both dashcams and also to not have to run wire from the front to the back (I believe the CRV has a 12V outlet in the back).
I was thinking a wedge style dashcam like the A119 V3 or Mini 2 may block too much of the rear view. And I feel there's not really a need for rear dashcam with a screen, which would too up more space. So when I saw that the WM1 doesn't have a screen and is more low profile than the A119 models, I thought it may be a good candidate to use as a rear dashcam. Thoughts?
