I just have a question and want to be sure just in case (and not destroy my mobius cam).
I have an external battery from "Goal Zero". The model is the "Yeti 150". Here is a link to it:
http://www.goalzero.com/p/164/Goal-Zero-Yeti-150-Solar-Generator
Could I simply plug my mobius cam using the 5 pin usb cable that was included with the mobius camera
into my Yeti 150 usb port? The specs on the Yeti 150 says that the USB ports are 5V (up to 2.1 A, 10 W max), regulated.
Also, does the mobius cam have a voltage limiter? I didn't see one in the settings. I don't need a voltage limiter as this is an external battery source and won't matter if it's completely drained out. I know that almost all car dash cams have a built in voltage limiter usually set at its lowest is 11.8V or 11.9V. The problem with that when using my external battery is that when the minimum voltage of 11.9V is reached, the dash cam will turn off automatically, but my external battery pack still has about 60% charge left on it. I'm still getting about 40 hours of continuous recording from 100% charge until the voltage hits 11.9V. But if the Mobius cam has no voltage limiter, then it would just keep recording until the external battery is at 0 or 1%. I'm guessing I could get as much as 80 to 100 hours continuous recording on a full charge so this way I won't need to keep recharging my external battery every 2 - 3 days.
