With a 160-degree wide viewing angle on both front and rear cameras, the Vantrue E2 relies on Sony CMOS image sensors and Novatek high-performance processor. The front camera has a 2.45-inch IPS display with built-in 2.4GHz and 5GHz Wi-Fi, a microphone and speaker, and support for up to 512GB U3-rated class 10 microSD card. It has a USB Type-C port for connection to a PC and the rear camera cable.
Videos are saved in MP4 format and can be recorded in various resolutions and frame rates. For example, time-lapse is supported with the 10FPS option, which save on recording space immensely. At the other end of the scale, 1944p front and rear recording at 24FPS is the highest resolution, with various options down to 720p front and back at 30FPS. If you wish to use only the front camera, a higher 2592x1944p at 30FPS is available.
You'll need a 5V DC supply for the dashcam, which has a working temperature of -4 to 158 degrees Fahrenheit (-20 to 70 degrees Celsius).
