Vantrue E3 Impression
runtohell121
Viofo & Vantrue - too many to list
Thanks to @Vantrue Dash Cam for sending the Vantrue E3 to test out.
Similar to the Vantrue E1 and E2, the design is more square/rectangular than other dash cam, feels sturdy and hefty. Nice quality when handling the dash cam.
This is a 3 channel dash cam that records in 2K front + 1080p inside and rear.
The user interface and settings are pretty straightforward, similar to other Vantrue dash cams. Nice to see that the power cable comes with a USB port, though it's not a fast charging port for other devices. The rear camera cable is a bit thick, making routing the cables can be a bit more difficult in some vehicles.
Some unboxing photos:
Main unit that houses the interior cam as well - note that the front lens can tilt most likely to compensate for the fixed interior cam as it's not a one size fits all for vehicles.
Rear camera (RC-05) - feels light and small, but please note that it is not interchangeable with the the rear camera from Vantrue E2. If you use the Vantrue E2 rear camera (model RC-03), the Vantrue E3 will only record in front and inside mode only. It will not record anything in the rear.
Video quality - daytime seems to be great. Night time is decent as well. Settings were mostly default, so I believe WDR was on. Parking mode is set to low bit rate.
Dusk time (front & rear):
Front:
Rear:
Night time in a lit parking lot, car parked/camera in parking mode:
Front:
Interior:
Rear:
Night time highway (front & rear):
Front:
Rear:
Day time parking lot, car parked/camera in parking mode:
Front:
Interior:
Rear:
Moved the Vantrue E3 over my new vehicle, the 2023 Tesla Model 3 RWD, even though the vehicle has sentry mode, I still installed a dash cam (Vantrue E3) with a battery pack (Cellink Neo) as a backup option and also disabling sentry mode from time to time to prevent battery drain. Yes, the camera is mounted upside down on a cellphone mount... Didn't really want to go through the hassle of pulling the pillar and routing all the cables.
At least lots of mounting surface on the back of the TV in the Tesla.
Yep! Can mount anything you want with adhesive as long as you don't mind it looking weird... I did wish the Vantrue mount could have rotated backwards, toward the screen so that I didn't have to use an additional mount to hold up the dash cam.
Also thought about using the Viofo A139, but didn't have extra interior and rear camera since it's being used with the Viofo A139 Pro on another vehicle and wanted a dash cam with 3 channel... Only had this one (Vantrue E3) laying around lol
It seem to be Okay cameras, my E2 just do what its supposed to do, and VS others i cant really point fingers at its footage.
Only negative point from me is the mounting system, but it do work ! Just i am such a fanboy for the traditional wedge camera seeing as i can not get any double or triple remote systems.
