ReburialGratify
Like many others here, I received the Vantrue E360 in exchange for a review. They were generous enough to send me the ACE bundle with the LTE module, which comes out to about $500. However, despite their generosity, I try to be as honest and objective as possible. I've also installed 6 dashcams previously - 5 Viofos and 1 Rexing, so I'm fairly comfortable around dashcams.
Luxurious Build Quality
When I first unboxed this dashcam, I was blown away by the presentation. It comes in a luxurious box with high-quality, artistic brochures that you would expect with an iPhone. The dashcam itself looks and feels luxurious. It doesn't feel like cheap plastic like most dashcams. Viofos look cheap in comparison.
This dashcam has everything - all the bells and whistles. This is like the Ferrari of dashcams. There is no way you're not impressed. It comes with a relatively large IPS touchscreen, which most dashcams do not have. Then it's capacitive, not resistive, which means you can move around the menus with a slight touch.
The software itself is very well designed. Everything is arranged logically, and you can move around with ease. It's leagues better than Viofo's. My only quibble is how video files are displayed. They need to fix this. The touchscreen shows 2 video thumbnails at a time. Each swipe on the touchscreen moves you to the next 2 video files. There is no way to jump around. So you can imagine how inconvenient this is with hundreds of video files. If you want to locate and watch a recording, you will need to download all the videos to a computer.
This dashcam comes with voice control, so you can verbally tell it what to do. This is a pretty cool feature, but I doubt I'll use it very much. If I want to lock a video, I can just press the large button on the side. It has infrared recording so you can record at night with no light. It comes with a handheld mount so you can use the dashcam to take selfies. During day trips, you can remove the dashcam from its windshield mount and connect it to this handheld mount. This dashcam has everything. It's a small engineering feat. Vantrue engineers spent a lot of time on this.
The unit is huge, so I initially thought this would be an issue, but I realized it's not a big deal. I placed the dashcam behind the right side of the rearview mirror. The mirror ends up covering up most of the dashcam, so you barely notice it. I wouldn't place it anywhere else because this thing is big and it will obstruct your vision.
I didn't like the design of the LTE module, which allows you to connect to cell service so you can stream. It's another piece of equipment that will make your windshield look crowded. Vantrue should have designed it so it's neatly tucked away out of sight, perhaps next to the car's fuse box. It comes with a long cable that makes it even more unsightly.
Video Performance was Mediocre
The top dashcams these days are marketed as 4K, but the truth is that there isn't a single dashcam on the market that comes even remotely close to cellphone cameras. They're all mediocre. License plates are a big deal for me, and they are illegible in every dashcam except for a few feet away. Don't expect this dashcam to provide true HD-quality videos.
When I heard that this was 5.2K, I assumed the picture quality would be better than 4K dashcams. Sadly, the resolution is spread across 2 cameras, so the picture quality ends up being worse. The front camera is effectively 1944P. My Viofo's camera is 3840P, which is a significant difference. I ended up downloading and comparing videos with ones from my Viofo A129 Pro 4K. As you can see in the attached videos, the Viofo's video quality is much better since it's in 4K. With the Vantrue, it was extremely difficult to make out any license plate numbers while driving. I could only make out the plate when I was parked immediately behind the car about 5 feet away. Anything farther, I struggled. With the Viofo like all dashcams, license plate identification was still very difficult, but I could probably make out the plate when the car was parked within 10 feet. 5 feet was clear and easy. I could also make out the number of cars driving close by.
With that said, the overall picture quality was decent, just not mind-blowing, which I would expect when this camera has so many other things going for it. I'm guessing the lower picture quality is the trade-off for a cabin camera.
There is a possibility that the picture quality is poor because the dashcam I received was defective. If so, I will update this review if I get a replacement.
Customer Service Problems
A few days after installation, I noticed the dashcam getting really hot. So hot that I reached out to Vantrue to ask if it was normal. They replied that it was, but soon after, the dashcam wouldn't turn on unless I plugged the power cable into the rear camera port. I'm guessing the heat blew something out. The rear camera and the LTE module (cellphone) no longer worked.
These things happen, but the problem was Vantrue's response. As a reviewer, I typically don't tell the seller or manufacturer that I received their product in exchange for a review because I want to know how they treat normal customers. Gloria, their customer rep, had me troubleshoot for several weeks to determine what was wrong with the dashcam. I've never experienced where the manufacturer forced me to spend weeks with them troubleshooting. I asked if she could just send me a replacement dashcam, but she refused. Instead, she offered to send a replacement hardwire kit. At this point, I had to tell her that I was a reviewer because she
required an order number to send the part.
Once I got the new hardwire kit, I eventually determined that both the hardwire kit and the dashcam itself were defective. As of the date of this review, she is sending me a replacement mount, which may remedy the issues I've been having. If the mount works, this means I spent about 2 months to get this thing working properly. If it doesn't and they need to replace the dashcam, it'll have been 3 months to get an operable dashcam. The Magnuson–Moss Warranty Act requires businesses to send customers a replacement dashcam if they can't fix any problems within a reasonable amount of time. So far, it's been about 1 month, which is definitely not reasonable for a new dashcam. I'm fine with waiting, but I don't think most customers would, especially if they dropped $500.
Gloria, Vantrue's rep, needs to be retrained. I don't know if she's their sole point of contact, but she's the one answering emails. She's going to lead to a lot of dissatisfied customers, negative reviews, and lost sales for Vantrue.
To be fair, I've found Viofo's customer service to be worse. They too are reluctant to send out replacements for defective parts. And they will try to pass customer issues to BlackBox, Viofo's main retailer on Amazon even if it's a warranty issue. I once purchased a Viofo dashcam, and it was missing a rear camera cable. (Apparently, missing items are an issue with them.) They insisted that I pay them $10 before sending it out. I mentioned that the cable was missing from the start, and that I could easily just send the entire box back to Amazon for a new one. The Viofo rep still refused to budge. I ended up dismantling the dashcam and sending the box back, which probably cost them hundreds of dollars and left a sour taste in my mouth.
Final Purchase Recommendation
Target Buyer. This would be great for an Uber or tax driver because this has 3 cameras - front, cabin, and rear. You can also buy a $150 LTE module that allows you to stream videos to the cloud. This is a convenient feature because recordings will be automatically downloaded to your computer for editing. This is also great if you want to capture interactions with police officers. The LTE module will prevent bad cops from erasing any incriminating evidence. I'm not exaggerating when I say this is a well-designed and well-built product.
If you're not an Uber driver and don't need a cabin camera, I would reconsider due to the lower resolution. Because Vantrue combined the front and cabin camera into one neat unit, they had to sacrifice picture quality. This leads to difficult license plate identification, which is crucial as recording accidents is my main goal. (Vantrue sells separate cabin cameras with higher resolution, but you end up with bulky cameras on a crowded windshield.) The cabin camera isn't worth the lower picture quality. If you're fine with this, then this is probably the best on the market.
The 2nd major concern is Vantrue's customer service. The hardwire kit and the dashcam were defective. Duds happen, they insisted that I spend weeks troubleshooting. That's unreasonable for a new dashcam, let alone an old one. If you get a dud, don't expect to get a replacement right away. I'd make sure I'd order through a platform like Amazon, which has a flexible return policy.
Btw, I would pass on the handheld mount unless you had a specific need. The video quality of a typical cellphone blows away this dashcam or even a 4k dashcam, so I'm not sure why they included this accessory. It is a solid mount though, built to last like the dashcam.
If you have any questions, feel free to ask!
Vantrue During the Day
Viofo During the Day
