Module 79L
- May 17, 2015
- Portugal
- AT11DA, SG9665XS, G1W-H
From day 1, occasionally and rather randomly, the AT11DA produces clips with much higher bitrates than the normal 12,40Mbps average. It usually happens to the full 5 min clips but there had been instances when shorter clips also had higher bitrates.
Here's the latest example:
These clips are from a roundtrip which took a little over 25 mins in each direction (the red line divides the two partes of the trip).
As you can see, the bitrate of the first clip is the normal one, there's a slight increase in the 2nd clip, the 3rd clip went back to normal but then the 4th and the 5th had a huge increase. When I returned, at 10:41h, the first 2 clips also had a higher bitrate, although not as high as the last ones of the away trip, and the 5th clip had the lowest bitrate I've ever seen the camera produce. In this camera, a typical 5 min clip is usually between 480 and 482MB in size and I don't recall ever seeing any 5 min clip smaller than that.
It's not that I think there's a problem with the camera, I'm just curious about why this happens.
Edit: the weather conditions were sunny with clear sky.
