Video playback
ecnar
Cleveland, Ohio
Are there any devices other than computers that can playback the files? I've tried a WDTV media device but the files cannot be played. I used 1440p 30fs. And, GPS.
Sent from my SCH-I545 using Tapatalk
Many smart phones and tablets play them just fine. Gps though... If you have the stamp turned off so that it's not visible as text at the bottom of the video, then I think the only option is a computer program like dashcam viewer.
I have tried a few things............although they are all without GPS
Laptop => HDTV via HDMI cable - This is OK
Both 1080p/1440p
Portable HDD => Samsung Bluray Player
1440p - This DOES NOT work
1080p - OK
I have converted individual files (to 1080p) fairly quickly using VLC player & then playing - This is OK
A bit tiresome if needing to do many files.
Screen Mirroring from Samsung Tablet => Samsung Bluray Player
1080p - OK
1440p - No Good
I have not tried screen mirroring from a Laptop as yet to see if that work - but I suspect it will be similar to a Tablet 😉
I suspect most Bluray players etc might only play up to 1080p, so you may have to use 1080p setting on the A119 or convert if wanting to play via the Bluray's interface.
I suspect if you use a Laptop/HDMI combo then it could be any resolution incl with GPS.
I've just tried playing on a Windows 10 tablet through HDMI to my TV and it works okay at 1440p and GPS. I had to use the 2nd screen only setting.
computer will scale the pic to suit, most devices like smart TV, BluRay etc will be limited to 1080p
