Jacquesx
Hello, I tried connecting the A119V3 (latest firmware 10 2024) with HK3 on my DACIA Sandero Stepway (end 2019). Red wire on 1 permanent power supply fuse, yellow wire on radio fuse with ‘on’ ignition, black wire ground. Nothing works except with yellow wire connected on fuse called ‘reserve-other accessory connection’ , wich activates the camera but it turns off after about 2 minutes, cut off by a relay, audible "clic" noise. Works correctly on the socket cigarette lighter and usb ordinary cable to GPS base but without ‘parking’ functions of course. Viofo tells me I need to go to garage to make special connections !
Does anyone else have the same problem?
