markm75
I ordered this a129 Plus dash cam and this hardwire kit.
I believe the hardwire kit was the correct one.
I used a fuse tap to an always on 12v spot and the other to ACC.
I've tried playing with parking mode settings, but the goal and my understanding, at least its how it works on the vantap mirror system in our other car, was that for parking mode on, the camera should shut off unless it detects a gshock?
I've tried parking mode timer off and on (90 sec), not sure what this even does, does off mean parking mode is off, or something else? I've set parking mode gsensor to max, set to auto detection. I have the main power usb going into the top of the unit, not the side. I think as of now I have the module set to 12.8 on voltage cutoff, though i may try setting that to 12.4, dont think its related to issues here. I also think i read i should hear 3 beeps after ACC is off if in parking mode, i had the sound off ill try again later with it on, though the one attempt at gsensor didnt do anything.
At one point it was in fact shutting off and i tried tapping on the main front unit (not sure if rear has gsensor), but it wouldnt come on.
I think it might have been after setting the timer mode, now after ACC is off, the unit either stays solid red on rec light or it flashes repeatedly after some time.
Does anyone know what the expected behavior should be here?
Also, it seems you must manually enter wifi mode all the time to use the app, is that also expected?
Thanks in advance
Thanks in advance
