Larlen
Hi there,
I have an issue with hardwired VIOFO A129 Plus Duo.
When Parking Mode is enabled in the settings, the dashcam will not turn off when ignition is off.
When Parking Mode is turned off in the settings, the dashcam turns off when ignition is off, so everything works as intended.
I wanted for Parking Mode to activate only if car is moved or there is some movement detected, but even with these options enabled the cam will stay on and recording light stays on 24/7 if the Parking Mode is enabled.
Hardwired correctly, checked by an electrician and another mechanic.
Any idea what could be causing the issue please? Thanks in advance!
