- Jun 2, 2023
- Mission
- Canada
- Viofo A229 Pro+A139 pro, Vueroid D21 4K, Thinkware U3000,
This may surprise a lot of people in here
There will be more tests done. So we will see the results in time lapse and etc. Also I am trying to recreate real world situations.Might have been a very different result with a little light on the face, for example if you turned the car around so that some of the light from the street lights was on your face. The Thinkware is winning here only because they have accepted an "unacceptable" amount of noise in the image when very dark.
Actually U3000 isGood comparation.
BTW the U3000 costs 2x of N4Pro
Did you try different EV settings?
Did you try rear camera for the same test?
I don't think the time lapse low fps option is not same as I mentioned above.i guess we will findnout on time lapse test
I'm not sure that 15fps means 1:15 exposure1:15 second exposure, that is pretty long even for the slowest of human movement.
I would not like such tricks to get brighter parking guard footage
Correct.I'm not sure that 15fps means 1:15 exposure
for 15fps it can be from 1/15 to any 1/1000, as well for 60fps it can start from 1/60 and go up to 1/1000
Depends on which camera you are talking about?@viofo would you clarify about exposure shutter speed for 15fps parking mode, please
what will be auto adjustable for such mode? F ? ISO ? A ?
HDR is suppose to work great at night. I actually feel it does work great from what I see. However the U3000 from Thinkware does not have HDR.would you try with HDR to be OFF? pls
I see motion blur when HDR is ON, while for static HDR is great, but at highway speed it is crushed license plate numbers IMHO
the Sony Starvis 2 promises built in HDR modes, again it's great for static
especially at low light that HDR just makes unreadable any numbers
I think that no or low motion blur is more important for dashcam then good dynamic picture range
and your above video license plate numbers test is the proof
p.s. I'm waiting for rear camera tests ;-)
I agree that it may not be best video quality. it was 11pm at night. We are not in a normal community so it gets pretty dark which is why I parked towards the cul de sac. Our backyard is pitch black.Looking at the video in post #1, I think the A139 Pro has about half the exposure time of the others, half the motion blur, the slower exposure time on the N4 allows it to do a much better job of the stars in the sky, the U3000 spoils the stars by turning up the ISO/gain so much there is far too much noise and the brighter parts of the image are over exposed, losing detail, but it does gain a little detail in the darkest areas.
If you pause the video at 1:47 and step through that second one frame at a time (Press ">"), there is an odd effect in the U3000 and N4 where his arm becomes very thin and almost disappears, while on the A139 his arm is always there, always solid and always the correct thickness! Not sure what is causing that effect? I don't think it is caused by motion blur. Objects completely disappearing does not make good evidence!
Nice work Ben.Here we go with Collision detection
new video being uploaded. Found an issue in testing resultsNice work Ben.
If you quote a measurement of milliamps, you must indicate at what voltage it was measured at.
Otherwise it will be false & misleading.
Example:
100mA @ 11.9 Volts = 1.19 Watts
100mA @ 14.4 Volts = 1.44 Watts
0.25 Watts is a big difference when operated with a 96Wh Dash Cam Battery Pack.
96Wh ⨸ 1.19 Watts = 80 hours of run time.
96Wh ⨸ 1.44 Watts = 66 hours of run time.
That is a difference of 14 hours of operation.
There’s an easier way.
Just quote power consumption in Watts.
The only reason I’m breaking your balls on this is because @Nigel broke mine. Lol
