RonB256
- Nov 12, 2018
- Trinity, Alabama
- SG9663DC
#1
Bring a Christmas present, budget is a big concern.
One thing that differs SG from many other companies is customer service does not stop at the point of sale. You'll get the same as long as you own the product - and likely even after that....I am impressed with the customer service
IMO your comment was stupid. You go right ahead and cut the head off a plug and wire it directly and then tell us all the story how your camera started smoking for no reason and how you left the information out that you cut the head off. Guess you don't realize is that a lot of dash cams are 5v so if you cut the head off you will be wiring 12v directly.IMO buying a hardwire kit is silly. All you have to do is take apart the power plug and use an add-a-fuse. I believe I made the right choice.
Does this approach provide battery voltage cutoff?the hardwire kit we sell is just for parking mode, if you don't need that then the standard power supply is fine for hardwiring
he can go right ahead and cut the plug off, we don't put the power supply in the cig plug specifically so it can be cutoff for hardwiring without having to buy something else, the power supply is in the cable about 50cm from the cig plug
Thanks. Just seeking to clarify, since the OP said a hardwire kit was silly and he only had to cut the cable. It's not quite the same result.No but this would only be for an accessory switched hardwire install, otherwise you would use the dedicated hardwire kit so that it changed modes when parked
Sent from my SM-G965U using Tapatalk
As per pricing on Amazon.com DC with a 64GB card and one CPL is for $290, so $275 without a card, add $30 for HW kit. A129 with the HW kit and one CPL totals up to 190 - $200.
Assuming amazon sellers provide one year warranty with the A129, spending 1/3rd more for far superior pre + post sales support and hassle free warranty that lasts at least twice as long, IMO is worth it.
You reviewed the A129 extensively. I suppose you didn't like it that much compare to the SG?
