CYPER
So I have Viofo A129 Pro Duo and my previous hardware kit died, so got sent a new one.
I connected the kit to my fuse box using fuse taps and measured the voltages with a multimeter to make sure everything works correct.
ACC cable receives voltage only on ignition and the red cable all the time. The car is BMW X6 50i F16 2015.
1 - When the USB cable from the kit is connected to the GPS module = camera powers on and works.
2 - When the same USB cable is connected directly to the camera = it doesn't power up.
3 - Another cable coming straight from a car charger when connected directly to camera = works.
I measured the voltage on the USB cable from the hardware kit = 5.54V I also measured the metal pins on the GPS module with the cable connected = 5.54V too.
Coming from car charger = 5.08V
So basically cable from kit has voltage, but only works when connected to GPS module and not directly to camera.
It is very weird. Any idea what is happening?
