mrtivo601f
- Feb 18, 2015
- United Kingdom
Can those of you with a Marcus4 provide your experiences with the type/make/size of micro SD cards you are using.
I have tried a Sandisk Ultra 32GB card, which works well, but due to the amount of storage, starts to overwrite files after about 3 days of my normal commute or less at the weekend. Sometimes this is too short a time to extract any video I want to keep.
I moved up to a Sandisk Ultra 128GB card, but this seems to lead to corrupt recordings after a number of files have been created. From memory, the first 16 files play fine, the 17th and subsequent files can not be played by Registrator or VLC, either from the SD adapter via the camera, as a USB drive or on the camera itself. Registrator is unable to repair the files either.
This could (and more likely is) a problem with my PC being unable to read SDXC cards, but I wondered if anyone has manged to reliably make recordings on 64GB/128GB cards, and what make/type/class/size they were, so that I can eliminate where the problem might be.
Ideally I'd like to go to 128GB, but if not, 64GB will be an improvement over what I can store right now, without carrying multiple SD cards.
My Marcus4 is running 4.7G firmware. The cards were formatted in the camera.
Thanks for any help you can provide.
