I have side cameras, but by chance not by design.
IMO the front camera should be fine if you get hit on the side or back, CUZ the front camera log what you do with your car, and if that is according to the traffic code, then what happen off camera can not be your fault or duty to log and present evidence of.
As the situation are if you do want to go there, the only solutions are to mount two single cameras either side, or use a dual channel camera to do the same.
And if you go dual channel, then most are a larger front unit and a small rear camera, but there now are a few systems with 2 small remote cameras, this could be SG9663DR - K2S pro there also are a few motorcycle cameras that are made with 2 remote cameras, and i suppose these will work in a car too.
The main problem are.
1: Ability to install the cameras, for good reasons you can not stick it to a window that can be rolled up and down, but some cars do have a small fixed glass on the rear doors.
If that is not a option you are left with mounting off the back of the B pillar filming out the rear door window.
2: Stealth most of us dont want really visible cameras anywhere on the car.
3: Curtain airbags, you do not want to be in front of those, but if you are close to the glass then it should be out of the way if a inflating airbag.
When my side cameras die, i will not undertake any serious effort in replacing them, only maybe if i get another system for testing that can be used there after i have tested front and rear will that happen.
My small car do not have any 12 V plugs outside of the one in the dash, so years ago to be able to test single cameras in the rear i got a 3 port splitter and wired that into my fuse box, this way i dident have to rely on a long USB cable from a power source in the front, and i could test the provided power source.
