unpaidbill
I just got my B-40C, and when I hook it up to the computer via USB, I can't access the menu. Does it have to be plugged into the car for power to make the menu show up, or did I get a lemon?
https://dashcamtalk.com/forum/threads/power-b40-dashcam-from-usb-data-port.17346/#post-225527It sounds like you're using a data cable for the connection. With that the camera is being treated as though it's a computer peripheral device. To use the computer as a power source only you'll have to get a power only (ie: a charging cable) that does not have the data lines.
An alternative to buying a charging cable would be to modify your existing cable and cut the data lines leaving only the power intact. There's a thread around here somewhere for that but I couldn't find it with a quick look.
