You have to see what circuits are constantly active before you tap into the fuse box. I tapped into the cig fuse since I only want the cams to be on when the car is running. If you want the cams be be powered all the time I would just run power direct from the battery with a 10A fuse and run the wire/cable through the firewall, or check to see if the ECU circuits are constantly powered.
