jakkso said:
http://www.foxoffer.com/viofo-1080p-gs9000-car-dvr-dash-camcorder-with-gps-p-311.html#.UUBusRAV_X4
Foxoffer was the name.
The one I am eying has these features and looks differently at the front.
No 4 x led lights but one led light to the right which is a long thin led.
After have a 178 degree car cam the video footage looks smaller.
The 120 degree one that I already have the video footage looks larger and easier to see number plates.
Your car cam is a 5 megapixel where the one I am looing at is 3.1 megapixel.
The video sample I've seen on the one below looks very good in daylight and one of the better ones I've seen at night.
Do you have a night video of yours recording ?
If your one does video like the one I am buying for night I'll go the one you bought from.
Here are the specs of the one I am looking at buying.
◎120 degree ultra wide angle lens
◎Super night mode, can get clear video at night
◎ Advanced H.264 video compression technology
◎ 1920x1080P FULL HD high quality resolution
◎3.1 mega pixels
◎ 2.7 inch high resolution LCD, can watch while shooting
◎ Matching IR Light for supplementing light at night
◎ Support HDMI high quality video transmission
◎ 3 resolution forms can be changed for video recording
◎ 30/60 frames per second for smooth video flow
◎ Equipped with special auto suction cup holder. Conveniently fix and use
◎ External GPS, record traffic speed, driving track (Optional)
◎ G-sensor to keep records of sensor data and real-time display on the player. (Optional)
◎ Powerful document protection, even in the recording process, the occurrence of sudden
power outages, machine damage, etc., video files will be intact
◎ Seamless recording; will not miss any data
◎ Adopt auto cigarette lighter power supply, to make the video recording while driving
◎ To start the auto automatic off; to start the video recording function
◎ Automatic circulating video recording, being able to set the record time for each file
◎Watch video while make video recording in driving. Support on-spot play back
◎ Time & date display and saving function.
◎ Motion detect, when the DVR detects moving objects, will start recording automatically
for 1 min, 1 min later will stop recording.
◎ Set the video recording time, stop recording when the setting time is up
◎ Screenshots function, can capture the video screen while video recording and reviewing
◎Charge through USB
◎ Human orientated operation interface
◎ Maximum 32GB or even bigger SD high capacity storage device
Feature
3
External GPS connector
AV Port
USB Port
Snap/delete
Power/light on/off key
TF slot
Fast back/Mic/left key
Fast forward/right key
REC /OK
MODE
HDMI Port
Reset
Speak
LED
Lens
